Inertia Ring
Discussion in 'The Garage' started by ccj8008, Jan 30, 2006.
  1. ccj8008
    ccj8008 1/2 ton status
    Apr 2, 2001
    228
    Polson MT
    I have heard good things about Inertia Rings, especially from people running 4 cylinders.
    Inertia Ring- Attachment added to flywheel to increase rotating mass. Helps prevent stalling at low rpm.
    Anyone with experience using one of these?
    Anyone using a heavier than stock flywheel (from a dumptruck or...)?
    http://www.4x4wire.com/tech/clutch/inertiaring/
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Not many 4 cylinders in this crowd...:crazy:
    The biggest problem i ever had with stalling on the trail was 95% carb related. I've since swapped to a diesel and have no more issues with stalling on the trail.
    Rene
  3. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    They're good for trail use, but for any kind of acceleration, it kills.
  4. ccj8008
    Apr 2, 2001
    228
    Polson MT
    I am running a 454 tbi with 5:13's. I am getting ready to swap in a Clark 5-spd with 7.5:1 1st gear, but hey, I'll take advantage of anything I can for low end grunt. Just seems like an easy addition that has not been discussed much.
    I got started in wheeling running IHC Scouts. For towing and wheeling they had a lot going for them, including big heavy flywheels.
    Can anyone recommend a source for heavier than stock flywheels for a 454?
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    dude if you got a 454 i wouldnt bother. you dont need the extra weight.
  6. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I don't think the rotating mass increase will do much for you. It'll smooth things out for sure but you'll feel it in the throttle response. It makes a big different on low rpm things like tractors that never see high rpm though.
    A hand throttle/electronic throttle/deft clutch foot/better gearing is the way to go. Anybody that has driven a manual BBC and a manual BBF knows exactly what I'm talking about.
  7. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Marine or industrial flywheels are heavier.
    I thought sombody on here had a marine flywheel on their 292 L6. Can't remember who now....:thinking:
