inexpensive install kits for 10bolt axles?
Discussion in 'The Garage' started by jjlaughner, Dec 2, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Where's the best place to get inexpensive install kits for 10 bolts axles? I have my 4.10's in the garage I just need to get them installed. The install kit has bearings and seals right? Anything speacial? If I just done bearings and seals not to long ago can I just buy the crush sleeves and go cheap?
    I'm reusing my rear carrier and maybe the front (If I can go from 3.08 to 4.10 on an open carrier). I have to do drivers side ball boints and a new drivers side caliper so I'm wanting to get away with regearing on the cheap side. /forums/images/graemlins/tongue.gif /forums/images/graemlins/1zhelp.gif
  2. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    drivetrainsuper store is kind of cheap
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If the existing bearings are fairly new, I would just inspect them closely. If there is no obvious damage, then I would reinstall 'em. /forums/images/graemlins/thumb.gif It isn't unusual for those bearings to last 200K miles. /forums/images/graemlins/cool.gif
  4. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    so just get the new crush sleeves for the pinions? sweet!
    I'm thinking about moving from the old trusty Valvoline gear lube to royal purple synthetic stuff /forums/images/graemlins/thinking.gif
    Auburn rear, open front
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I would check with Auburn before just swapping fluids....Probably OK though....
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    yeah I have to use the GM LSD fluid with regular gear lube, I dont think you can or are supposed to with the royal purple /forums/images/graemlins/thinking.gif
  7. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  8. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    2.) What kind of oil should be used with an Auburn differential?
    It is important when installing Auburn differentials that a high quality, non-synthetic 80w90 GL-5 oil, treated with GM or Ford limited-slip additive (also known as friction modifier) be used. Three ounces of additive will treat one quart of oil.
