Inexpensive Scan Tools
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pcorssmit, Jun 4, 2001.
  1. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I was at Checkers today and they have a scan tool for $150, your choice of GM, Ford, or Chrysler OBD1. I think they are made by ProScan, or something like that, will call and check. I was wondering if anyone has any experience with this or other budget scan tools. Thinking about going in on one with a couple buddies.
    Thanks,
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I always use the paperclip trick on my Probe and my old Van....
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Pete, I've got the Auto X-ray scanner from <A target="_blank" HREF=http://www.autoxray.com/scanners.htm>http://www.autoxray.com/scanners.htm</A>. Picked it up at Checkers for $150. It works sweet! Just make sure you get the latest model, as pictured on the web site. One Checker I went to still had the old version on their shelf. [​IMG] You can tell the difference by the keypad. The layout of the older model looks totally different.
    Mike, these things actually allow you to look at the data from the computer in real time. Way more info than just a flashing light in the dash. It's an awesome troubleshooting tool! You can see exactly what's going on. Many times the "error codes" are nothing more than a symptom of the real, underlying problem. With one of these tools you can get the actual readings from the sensors to see what's really going on under the hood.
  4. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    Thanks. I'm trying to get my brother's TPI GTA to run worth a crap, but would like to have one for the Blazer too. Pep Boys says they have one for $100, will probably go check out both after work tommorrow. Harry, it there a picture of the keypad one yours somewhere (so I can tell which one they have)? What's the difference between the two?
    Pete
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I can't find a decent picutre on their web site any more [​IMG]. But what you don't want is the XP240. The new model is called an EZ-Link. Checker uses the same part number for both of them. :-(
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I'v got a auto X ray scanner too. It works great. Its worth every dollar it cost. Used it the other day on a buddys truck. He had taken it to a shop they charged him $300. And they still didn't fix the problem. Plugged in the scannner.No trouble codes showed. But the Operating data readings wer'nt right through the o2 sensor. Replaced the sensor and fixed the problem.
    Then we went to the shop raised H### and questioned the competence of their mechanics in front of their customers and got his money back.
  7. dyeager535
    26,980
    Whatever you look at, it appears from what I have seen and heard of scanners, you want one that will give you "real time" data. I looked at one on closeout at a local chain, and it did not give real time data. Check online for comparisons/reviews before buying.
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The Auto Xray EZ-Link does do real-time data and also has a data capture mode for intermittent problems. I'm most impressed with mine. [​IMG]
  9. bart
    bart Registered Member
    Mar 15, 2000
    69
    Eastern PA
    Try Turbo Data System Technologies. www.turbo-link.com
    This runs on a laptop and interfaces with every GM OBD I (up to 1992) computer...it's really neat and only costs $149. Lifetime support and upgradesi ncluded...can do logging, etc.
    I have it and am very satisifed with it.
    bart
  10. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    I picked up an MPSI Prolink 9000 on ebay last year for $125...can look at the big three up until 94....same thing we use at work....provides codes and real time data.
    Azblazer
    1979 K5 350 TBI
    1976 K5 Chalet
    If it ain't got arizona pinstriping.....you ain't wheelin the pee outa her!
  11. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    Bought the Auto Xray EZ-Link yesterday, forgot to get batteries. Came across the fuel pressure gauge in the garage yesterday, decided to give it a whirl. Bingo, fuel pressure is 24 psi, spec is 40-47. Was too dark to find the cause, suspect the regulator but should find out for sure tonight.
    Pete
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Pete, be sure to disconnect the vacuum line to the regulator before testing the fuel pressure. The vacuum line causes the pressure to drop at idle, but 24 PSI sounds too low, even at idle. [​IMG] I think that when stock, my TPI ran around 35 psi at idle and 42 psi disconnected.
  13. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    Was following the procedure outlined in the HELM manual. Didn't mention disconnecting the vac. line, it should develop and hold 40.5-47psi when not running. I tried cycling the pump a few times as well, it builds and holds 24 psi.
    Pete
