Info about build codes??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jarheadk5, Apr 4, 2000.
  1. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Does anyone know where I can find a listing of the "build codes" or whatever they're called? The ones on the sticker in the glovebox. I'm kinda curious to see if my 3.73's are factory-installed, along with a few other things. Thanks!
    [​IMG] Semper Maintenance!
    [​IMG] So many ideas, so little money...
  2. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    I have a Michell Repair book for accident apprasal. I'm not sure if this will coveer what you need can you expand on it alittle.
    C'moe
    <font color=black>the blazer is "Back in Black"
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Don't have the web site handy (there are a few), but:
    GU4 = 3.08
    GU6 = 3.42
    GT4 = 3.73
    G80 = Gov-Lock
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  4. Steve88
    Steve88 1/2 ton status
    526
    Sunny Arizona !
    Hey I just checked mine and I've got 2 "G"s on the sticker.
    GT4
    G80
    So according to that last thread I've got factory 3.73 gears and a Gov-lock. OK so what's a Gov-lock? Factory locker I presume? Would this be in both the front and back? Or is it posi? Or whats the difference? Someone explain?
    Hey also while you're typing, seeing that I have 3.73 gears already in there, would it unreasonable to assume I could put 35's on without a problem? (Assuming proper lift/trimming to get them to fit). Am I over-assuming what my gears are set up to do?
    <font color=red>Steve88</font color=red>[​IMG]
    88K5 Silverado
    thunderdog@metallica.com
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    From what I understand a Gov-Lok is a factory Posi traction.
    3.73 with 35s? sure I have a few buddies running that. I run 33s with 3.73 and I like the gettin to the trail speed. My SM465 granny gear makes up the difference for me on the trail.
    Rock ON![​IMG] 72 K5 [​IMG]
  6. Steve88
    526
    Sunny Arizona !
    Hey Burt, not sure what you meant by you like the "getting to the trail speed" with 33's. Maybe I don't get the speed difference between 33's and 35's? I thought the difference is size balances out to the difference of how much more power it takes to move the 35's instead of 33's? I.e. it takes a little more power to move the 35 but you're traveling farther per revolution of the wheel right? So wouldn't a 35 effectively go faster on the highway at crusing speeds than a 33? Explain o' wise one!
    88K5 Silverado
  7. Burt4x4
    6,854
    hmmmmm
    I think its just the opposite.
    I was refering to MPH to RPM
    I'm pretty sure if you run 33 w/3.73 the at 2800 RPM you should be somewere around 65MPH
    Now if you switch to 35 then to get to 65MPH you RPM would need to go up to somewere around 3000RMP
    I don't have nothin to back this up except what I think of how it works!!?????
    Yes ? NO? Mabie so?
