info needed for 700R/241 on a 73 blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by arq, Jan 28, 2003.
  1. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    also, will i require a new Xmember if i want to put in a 700R/241 combo on a 73 blazer??
    thanks,
    ARQ.
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    What's it replacing?
    Yes, I'd imagine you'll have to move your crossmember. Best bet is to just get the whole setup from a donor truck. Also, the 700r4 has an electrically controlled torque converter lockup, so I'd imagine you'd need to get the unit (computer? - never traced those wires, sorry) that controls that.
    Oh yeah, and speedo on tail-shaft of t-case is electric on I think all np241's, so you'd need that setup too.
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    more: info needed for 700R/241 on a 73 blazer
    there is a th350 with a np203 in it. as for the wire setup, the torque converter requires a 12v source when at cruise speed. the voltage should cut when hitting the breaks or manually shuting it off. I am not too concered about the speedo, yet. GPS reciever should take care of that :-)
    thanks,
    ARQ.
  4. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    Re: more: info needed for 700R/241 on a 73 blazer
    go to 700r4.com they have a few ways to hookup the lockup converter. They have good diagrams too.... probably the easiest way for you to go about it would be the bosch relay setup, then as long as your brake lights work, the relay will work.
  5. bigjbear
    Feb 18, 2000
    13,964
    446
    Marietta GA
    [/ QUOTE ] Got to love the '73 for that. Mine "sees" the satlites much better through the 'glass roof than a steel cab.
