info needed on np208 or nv231/241 etc
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by m j, Jan 4, 2002.
  1. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    for use on sm465.
    pics would be great
    spline count, adapter, dimensions, and P#s etc.
    thanks
    both my sm465s have worn output shaft so finding replacement is on the menu and would like to choose correct one that will work for future plans
    thanks in advance for any help
    Michael
    formerly 77chev
  2. tRustyK5
    Jul 23, 2000
    36,183
    1,388
    E-town baby!
    81 and up SM465's that came with the NP 208 were all 32 spline. Should have the round 6 bolt generic type T-case adaptor and I would guess the 241 would bolt up to it without too much problem.
    I had a SM 465, NP208 out of my Jimmy laying around for a few years and got rid of it for almost nothing before I found out it was 32 spline...[​IMG]
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    adapter length?
    formerly 77chev
  4. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    8.5 inches long
    Russ
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    cast iron?
    formerly 77chev
  6. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Yes, it is cast iron. I have one outside. If you need any specifics for it I can get them for you in the daylight tomorrow.
    Russ
  7. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    here's a pic: <a target="_blank" href=http://community.webshots.com/storage/1/v0/5/31/62/28553162PebQwyfAAV_ph.jpg>http://community.webshots.com/storage/1/v0/5/31/62/28553162PebQwyfAAV_ph.jpg</a>
    '95 Chevy Silverado 1500
    5.7 V8-NV4500- 3.73 rears
    See My Toys: <a target="_blank" href=http://community.webshots.com/user/wdb172454>http://community.webshots.com/user/wdb172454</a>
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    thank you
    formerly 77chev
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    have you done a comparison of the planetaries in a 241 vs 208?
    Klune stsrted with 231s for the jeep crowd I think, wondering if the 2XX have any advantages over 208
    adapter casting looks thinner then the old stuff
    formerly 77chev
  10. tRustyK5
    Jul 23, 2000
    36,183
    1,388
    E-town baby!
    I was talking to RyeGuy about good planetary candidates and he recalled the 208 was difficult to use for some reason. The 231 is a 3 gear planetary versus the 241 6 gear planetary.
    32 spline 241 planetary sets are not hard to find...any 1/2 ton Chev from 88 and up with the 5 speed had one. There must be quite a few in the wrecking yards. I was thinking of checking some tranny shops out. You would think they'd see a fair number of cracked and broken T-cases.
    Rene
  11. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    What year vehicle did that adapter come from? The one I am using looks a little different. Mine has a flat mounting face (no grooves) where it bolts up to the 241 and the crossmember feet are up high for the double hump style crossmember.
    Russ
  12. 95 Silverado
    Nov 9, 2001
    467
    Central PA
    it's from an '83 full-size blazer
  13. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Thanks, I guess the 241 and 208 adapters must be a little different. Mine is from my 90 Blazer. I'm guessing the bolt patterns and lenth are probably the same though.
    Russ
