info on 427 tall block install into 84 frame???
Discussion in 'The Garage' started by Supreme70, Feb 7, 2005.
  1. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    I need to know if there are things I need to look out for, and is it a direct bolt in?????:confused:
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I haven't done it but I will try and help. If memory serves me, it will bolt right to your frame if you have the truck engine mounts on the motor. The only issue is I think tall deck motors come pretty close to the vaccum booster mounted on the cab.
  3. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    someone said the starter bolts to the trans bell housing?? What about headers?? does some make them for that motor??
  4. Lonnie P
    Lonnie P Registered Member
    Feb 7, 2005
    28
    Pittsburgh, PA
    The engine will bolt in with the factory SB or BB mounts.
    The starter will bolt to the block same as a regular engine.... you only need the belle housing mounted starter if you are bolting it to the c50 c60 truck trans.
    The alternator bracket may need slotted to fit the taller block.
    Some large truck harmonic balancers had wider belts. This will require a standard car or pickup balancer & pulleys from a 396/427..... not the 454 as it is counterweighted.
    my Hedman headers fit well.
    I have the hydroboost brakes & they fit with the tall Moroso valve covers, not sure how the clearance is on a vacuum assisted brake unit.
    Hope this helps.
