Info on 84 Bobtail plane tug
Discussion in 'The Garage' started by glenntx, May 12, 2004.
  1. glenntx
    glenntx Registered Member
    May 12, 2004
    24
    Texas
    Bought this the other day: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&category=5348&item=2477329435&sspagename=STRK%3AMEBWN%3AIT
    My plan is strip the huge axles off, get some spring hangers installed, then install the D60 front w/ electrac and 14 bolt rear w/ detroit, off my wagoneer and go wheeling.
    Should I just get some spring hangers from a junkyard? Or are there better options? I was thinking on the rear of the rear spring I might flip the hanger so the shackle will hang down. Any thoughts?
  2. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I would be tempted to just leave it the way it is except I would tear out the 6.2 Diesel, and install a 454 Big Block in it. It would be the ultimate Rock Crawler.
  3. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    SWEET! /forums/images/graemlins/peace.gif
    Any way to use those axles (4 wheel steering!), remove a bunch of weight, cage it and go with 44's?
  4. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    6.2 seems like it would crawl just fine, and the economy would be nice. Also the thing only goes 10-15mph in the current set-up, don't need much engine with that kind of gear reduction.
    I am suprised to read that you want to swap axles. You paid a lot of money, and I'd think that those unique axles would be the reason. Why pay that much just to strip the axles /forums/images/graemlins/confused.gif You could have got any truck and done that. But its your truck /forums/images/graemlins/grin.gif
  5. glenntx
    May 12, 2004
    24
    Texas
    I bought it primarily for the low miles (7500). The axles have a total gear ratio of around 18:1, 3:1 at the diffs and 6:1 at the hubs. I'm hoping to sell these to someone building a rockcrawler or monster truck or something. If I could figure out a way to change the ratio back to 1:1 at the hubs I think I would keep the axles as they are and just add leafsprings. I'll have to find out if that's possible.
  6. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    Send me a pm with your info.
    I may be intrested in your axles.
    I have a few m1008's & lots of parts.
  7. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    That has an iteresting clocking position of th transfer case. I bet some people with super tall lifts might be intersted in that adapter !
    Blake
  8. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Just remember - the factory setup has zero travel!!! So no go on the excellent rock crawler with no suspension! I think you would be better off buying a stock GM truck with running motor and t-case because this setup would be super heavy and has no advantage over any other GM truck in my opinion.
  9. glenntx
    May 12, 2004
    24
    Texas
    Yeah, like I said in the first post, it's definitly gonna need some springs. I'll have to extend the frame farther back to run rear leaf springs.
    Anyone have any leads on some weld on, or bolt on, spring hangers?
  10. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    I would leave the frame the same length it is now and go with a four link coil over suspension. Sell the axels to someone else and run either 1 ton axels or 2 1/2 ton Rockwells. Ditch the 208 in favor of a doubler. Cut off the step and call it good.
  11. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    not to rain on your parade but did they give you any idea about how many hours were on it? does it have an hour clock (time engine was running). it would not suprise me if that thing had thousands and thousands hours on the engine, not just 7500 miles of driving time.
    But i hope it works well for ya /forums/images/graemlins/thumb.gif
