Info on 90's GM truck motors?
Discussion in 'The Garage' started by Eric W, Feb 26, 2005.
  1. Eric W
    Eric W Registered Member
    Feb 14, 2005
    40
    NE Maryland
    Are there any info pages on the net about 90's GM truck motors? I found plenty for 73-87 models but nothing on 1990's truck motors. In preparation of getting a K5, I want to explore all options of future upgradability since the truck I'm most likely to get is a 305 2 barrel carb'd unit. Ive never swapped an engine before but I figure a truck would be a great platform to start out on. I'm actually entertaining the idea of using a LT1 motor. They're fairly cheap (compared to LS1 or LS2), plenty of performance parts. I have an LS1 in my cage right now but those are expensive to buy and LT1's have better low end torque which would be great for off-roading.
    Basically I'm looking for- fuel injection, more HP and torque, and better efficiency then the 305 from an 86 model. I also thought about the possibilty of diesel but the conversion would be very expensive, not to mention I don't know a thing about diesel motors.
  2. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    I would pass on an LT1. I happen to have one and it works real well for what I do, but it does have a few weak links including the Optispark distributor. I would consider a 96-up Vortec 350. They are getting cheaper, make good power and are somewhat upgraduble (although the aftermarket has overlooked the Vortec).
  3. Eric W
    Feb 14, 2005
    40
    NE Maryland
