Info on a 14 bolt lincoln locker???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scout, Nov 14, 2001.
  1. scout
    scout Registered Member
    Nov 14, 2001
    9
    Hey guys, just wanted to know if anyone knows alot about welding up the spider gears in a 14 bolt. A web site would be helpful, but anything would do.
  2. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Weld between the teeth so the spiders cannot turn.
    Most times you will weld the side gears to the carrier, but in the 14 Bolt, if you decide you don't like the spool and want a Detroit, you're screwed because the Detroit doesn't replace the carrier for the 14 Bolt.
    Most guys I hear are using 6013 rods in a stick welder to "Lincoln Lock".
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Rene (tRustyK5) has been running this set up for quite awhile. You might shoot him a PM and get his advice.
    <font color=green> Too bad ignorance isn't painful </font color=green>
