Information on 208 Tcase
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dansblazer, Mar 28, 2005.
  1. dansblazer
    dansblazer Registered Member
    Sep 17, 2004
    32
    Oshawa, Ontario
    Is there any way to change the output shaft on the 208 tcase. I want to adapt a Double Cartisisan ( cv drive shaft ) for the rear of my 81 Blazer. I was told that I cannot use a slipe yoke on the rear cv drive shaft. I was told that I need to change the 208 tcase output shaft to be fitted with a flange for this type of drive shaft. However I can not find the kit or ?? for this converstion.
    Does this kit exist.....
    Dan
  2. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    find a dodge case and swap in the chevy input gear and use the chevy addaptor. this will get you a factory fixed yoke rear. or get a slip yoke eliminator kit or sye kit.
  3. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    There are parts out there made for making a slip yoke CV shaft . All the big driveshaft places make one with it . I run one . Instead of the flange on the end there is a slip yoke attached :k5: :k5:
  5. dansblazer
    Sep 17, 2004
    32
    Oshawa, Ontario
    Thank You for the reply, I am contacting them and moving Ahead....again thanks for the information.
    Dan
  6. trailblazer86
    trailblazer86 1/2 ton status
    May 16, 2004
    112
    North Shore of Lake Ontario
    www.Driveshaftsuperstore.com
    This place is advertised in the U.S. offroad magazines
    Slip yoke with CV to remove vibrations.
    I get most of my shafts built at Dynamic shaft in Scarborough. They can make one up for you also.
    Hey! I'm just down the road in Baltimore... North of Cobourg
  7. stevewix
    stevewix Registered Member
    Dec 2, 2004
    83
    az drivelines np208 sye=bs.
    my driveshaft collapsed (somebody must've jumped it :cool1: )
    and ripped the sye out of the back of the t-case. so if you DO buy it, do yourself a favor and buy the 7" long travel version lol.
    other than this minor inconvenience, it DOES work great at removing vibration and strengthening things up a bit. i liked mine- until i collapsed it.
  8. dansblazer
    Sep 17, 2004
    32
    Oshawa, Ontario
    Thanks Guy's you have made up my mind...I going with the 205 I just purchased a 10 spline and comverting it to a 27 spline for the 350 tranny. Know I need to sell the 208 seing I have had the thing completely rebuilt.... anyway thanks......
    Dan
  9. trailblazer86
    May 16, 2004
    112
    Here is something more for you to ponder.
    I have a TH400 from an Impala sitting on the garage floor. Pretty hard to hurt a 400. I was thinking of puting it in front of my 208. Too much work finding the adapters etc.
    Keep it in mind I may let it go as I was thinking of going with a TH350.
