Initial Ignition Timing?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBadJap, Jul 25, 2003.
  1. BigBadJap
    BigBadJap Registered Member
    May 23, 2003
    76
    Alberta, Canada
    Hi, does anybody know what the stock initial ignition timing is supposed to be on an 89 TBI 350?
    Thanks!
  2. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    Should be set to 0* while the computer advance is disconnected. There's a brown 1 wire disconnect near the brake booster on the firewall. That has to be disconnected when setting the timing. There should be a sticker on the radiator/grille support when you open the hood that has all the info on it.
  3. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    It is set at 0*. Before you set it look for a brown or tan wire with a black stripe (IIRC). It is usually found above the passanger side head on the firewall just sticking out of the loom. It will have a connector. Undo the connector! This tells the ECM that you are setting the timing (basically).
    Just remember to hook the wire back up when your done.
  4. BigBadJap
    May 23, 2003
    76
    Alberta, Canada
    So there is NO initial ignition advance??? I guess that makes things easy!
