injecting the rat!!!!!!!!!
Discussion in 'The Garage' started by HELLBENT DESIGNS, Jan 5, 2006.
  1. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    the1967 gmc's rat in gonna get multi port fuel injected ( thanks bigpappab ) bought his mercruiser 502 ramjet setup! currently have a 1990 rebuild 454 with a cam edelbrock 750 carb etc. tempted to build my 454 4bolt main block with a few parts i have been collecting ... eagle 4349 no-twist crank factory 502 hydraulic roller cam etc. looking to run pump gas, anyone know flow-hp potential of the merc ram setup? thanks:D
  2. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I'm interested to see some replies as this is the same setup I plan on running when I rebuild/drop in the 454 I got from Ryan B.
  3. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    just to make certain, you have a GenV (or Gen VI) 454?
    iirc, the 502 stuff won't interchange with stuff from a MKIV BBC block.
  4. dyeager535
    26,979
    Does the Ramjet have a knock sensor?
    I hope the stock fueling parameters aren't too far off for a 454...
  5. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    i think it does have a knock sensor! as far as fuel if i can match what the unit is made to i will or see if i can burn the chip:dunno:
