injector pump questions???
Discussion in '1982-Present GM Diesel' started by steve_kibbe, Sep 6, 2004.
  1. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    are both wires on the injector pump to have power when ignition is in run?? How can I check the injector pump for correct opperation? I did remove injector lines from injectors, some squirted fuel, some didn't. Getting good pressure to the pump. Still having problems from the baptism of my truck.
    Thanks for any sugestions
    Steve /forums/images/graemlins/truck.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/confused.gif
  2. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    Hey Steve
    1st up Welcome /forums/images/graemlins/thumb.gif !!!
    next i can tell ya the pink wire should have power all the time yes
    the green wire however is a cold advance and should only have power when the motor is cold enough to require the timing to be adavanced a little bit
    and as far as testing the injector for proper out put pressure unlees ya have the proper tool i am all most positive ya need to take it in to a shop that has a way to aucatly test the true out put line pressure in real psi not just oh ya it squirts good :-)
    Hope it helps and good luck
    Randy
  3. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    thanks Randy, I'm pulling it saturday. I'll let y'al know the progress. /forums/images/graemlins/thumb.gif
