Injectors
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pr1aw, Jun 26, 2003.
  1. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    Going to rebuild my TBI.
    1. Replace with over the counter injectors. $64 ea
    2. Replace with Holley injectors. $75 ea
    3. Replace TBI with Holley TBI (Summit) $340
    Thanks in advance for information.
  2. Jays Beast
    Jays Beast 1/2 ton status
    Aug 7, 2002
    538
    Chandler, AZ
    Go to autozone and buy a rebuild kit, replaces the o-rings and gaskets and filter, don't need to replace the injectors unless one or both are not working.
    Jay
  3. pr1aw
    Sep 17, 2000
    144
    San Diego CA
    Going to do that too. I'm figuring with 210,000 the injectors might be tired.
  4. dyeager535
    26,975
    Check around online, I bet you can have them tested (or do the testing yourself). I know you can with TPI injectors, as well as "sonically cleaned". Doubt its any different for TBI ones.
    About $25/injector last I looked. Also make sure the flow is similar as well.
  5. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    I read an article a long time ago about the Holley Throttle body. It comes with a new higher pressure fuel regulator and larger throttle bores. I forget the actual power numbers, but it was a respectable amount. 10-15 HP if I remember correctly. You can also use an injector spacer to get more flow and a few more horsepower. This is just my opinion, but if your going to rebuild it anyway you might as well build some more power into it.
