Inline 6s in K-5s
Discussion in 'The Garage' started by MEPR, May 4, 2003.
  1. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    ALright call me an inline motor nut but i gotta know. Did k-5s come whith 292 inline 6s. And if so do you think anny of em are left?
  2. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    yeah, they couldnt have gotten very far /forums/images/graemlins/ignore.gif
  3. bigjbear
    Feb 18, 2000
    13,967
    448
    Marietta GA
    I've only seen one, but it was in a 2WD.
  4. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    i dont realy know why but i whant to have a k-5 whith a 292 in it. And if it is a 2wd it wont be that hard to convert to 4x4 right. /forums/images/graemlins/k5.gif
  5. bigjbear
    Feb 18, 2000
    13,967
    448
    Marietta GA
    Prob easier to convert to I-6 from V-8, than 2WD to 4WD.
  6. bigjbear
    Feb 18, 2000
    13,967
    448
    Marietta GA
    I'll get stoned for this but I've seen a couple Broncos w/ the 300 I-6, don't know how bad you want to stay in a Chevy, but its an option.
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    The I-6 was supposed to have been the standard engine for several years. In fact, that was one of Ford's marketing angles: that Bronco came standard with V-8, Blazer came standard with I-6. I also heard that there was a factory soft-top option. I've never seen either of those or a 2WD blazer.
  8. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    oh i already have a ford 300-6 (read my sig, 4.9L) and i love it. It actually seems to pull better than many stock 350 cevs in pick ups, thats why i was wondering about the 292 in a k-5.
  9. bigjbear
    Feb 18, 2000
    13,967
    448
    Marietta GA
    Yep, I remember you posting about the F-150 in the past, that's why I brought it up.
    The 292 uses the same bell as the the V-8s, right? It can't any worse than a SBC to BBC swap. Prob easier-more room to work w/.
  10. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,139
    14
    Bangor,Pa
    before i bought my current 72k5,i had found a 71 with a i6 and a 3 on the tree.the guy said it was standard when he bought it.ive also seen 2 first gens 2 wheel drive blazers.they are hard to come by.i dont think they made many of them.
  11. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I don't think many actually left the factory with I6's. I haven't seen one. I have seen them with V6's, but not I6's. They are supposed to be out there though.
    I to am going to put an I6 into a Blazer for my next project. It is going to be a hardcore rock only rig, and I want the torque and mileage of the I6.
  12. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    The blazers came with 250 I6 until 1980 or so. to put a 292 in the passenger side frame mount has to be moved ahead 2 inches or so. The 292 is a really torquey engine and is great for crawling but doesnt like going over 4000 rpm. i had one until a couple months ago. It would spin my 38's for fun.
  13. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    The 292 L6 was never offerd in the K5's. The 250 L6 was offerd untill 84. The 262 (4.3) V6 replaced the 250 L6 in 85 and 86. From 87-91 the standard engine was a 350.
  14. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Now your talking ! I am installing a 292 in my K-5 right now .
    As others have said a 292 was a 3/4 Ton and up offering only.
    My last truck was a GMC K3500 w/ a 454 and I loved it but I think that a true off-road capable Blazer ought to have bottom end balls at idle and not to many motors will pull down low like a 292.
    If you do decide to put a 292 in a Blazer there are a few things to watch out for.
    First ( as stated by others earlier ) is the passenger side motor mount is farther forward than the 250's & V-8's .
    The flywheel has larger bolts that hold it to the crank ( 1/2 instead of 7/16 ) and there are 3 allignment dowels on the crank instead of just one. Note: some early 292's used the smaller flywheel bolts and one dowel.
    A lot of 292's came in C-40's / 50's / and 60 series trucks in the late sixty's and early seventy's and they had wider drive belts than did the 1 Ton on down trucks. You may have pulley accessory problems if you get one from a large truck.
    The harmonic dampner has the drive belt groves in different spots ( the groves are made into the balancer )so get all of the pulleys off of your donor motor- they are not all the same.
    Good luck ! If you decide to do a 292 swap and Ya' got questions feel free to ask anytime . Tom
  15. jhrody
    jhrody 1/2 ton status
    Feb 16, 2003
    129
    Elmhurst, IL
    my '78 had an '84 truck 250 (2bbl and dual outlet exhaust)in it. Very capable I thought. Never had problems with inadequate torque.
  16. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    I just sold a '70 with a 6 and 4 on the floor.
  17. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    id like to see an I6 in a k5... you know 3406b, 3176, c-16 somethin like that. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  18. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I have seen a 1/2 ton Chevy with a ford I6 300. The Ford 6 is a good motor in my opinion. Beat it forever then some more.
  19. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    yeah the 300-6 was the only reason i bought my f-150. If it had a 351 in it i would have kept looking (probly bought a k-5). But yeah just wait untill you get a ford 300 bored out, mine is running 310 actuall cubs in it right now.
  20. ben427
    Mar 10, 2002
    1,123
    Bleh, the first and the last arent bad, but id stay away from the 3176. can you say grenade???
