Inline pump for TBI swap
Discussion in 'The Garage' started by BillyBob, Jun 24, 2003.
  1. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    Rather than going through the buisness of looking for a tank and sending unit for my TBI swap, I wanna use an inline electrical pump. Does anyone know of one that I can use? everything I seem to find on Summit Racing looks like it's for high PSI systems. I think TBI needs around 20PSI, correct? Doing this would help prevent me from dropping the tank , since that's a PIA. I need reccomendations if anyone has any. BTW, the system I'm using is from my 87 K-5 (tank is shot and sending unit is mising the connector to it)
  2. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Turbo City has one....
    Marv
  3. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    this is the one i was planning on using
  4. dyeager535
    26,979
    Some people have run injection without baffled fuel tanks, but if you get it down to 1/4 tank or so regularly, and accelerate hard or climb hills, you'll need some kind of "reservoir" for the fuel pump.
    I've uncovered the pickup in a carbed car before on acceleration, but with EFI, that stalls(kills) the motor.
  5. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    I would use a Walbro pump from Howell. I have used Holley's before and it failed, and Holley would not replace or refund until they inspected it. Took them 3 months to decide to honor thier warranty.
  6. BillyBob
    Feb 23, 2000
    557
    Dumont, NJ
    Where can I find this Walbro pump that you're talking about? I looked on summit's site, but no luck.
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    This is some good info I got from a friend. He went to great lengths to find all this info out. I posted it all so people doing a search will find it. The fuel pressure is controlled by the regulator. As long as the pump is rated for at least the pressure you need you are set.
    External High pressure
    Application 1993 Bronco Autozone P/N E2000, about $75, and uses a hose clamp on each end, the output side uses a removable fitting that can be modified to take an AN hose end. The inlet side is low pressure and using the clamp shouldn't be a issue.
    In Tank High Pressure
    Application 1986 Chevy Camaro with Fuel injection. Look in the bottom for an inlet screen just inside the pump, some versions don't have it. You'll find one if you try more than once. This has a clamp on hose also, but is in the tank and won't be a safety issue.
    In tank Low Pressure pump
    Application 1979 Chevy Monza with 3.8 liter V6. This is about half the size and half the price of the high pressure pump and was meant to feed a 2 barrel carb. It makes a good sump feed pump.
    External Filter
    A good external filter is a Purolator F33144, this comes in different brands an is another generic GM part. You can get AN hose adapters from several companies for this filter. The smallest size adapter fits an AN6 line. Probably the most economical filter designed for fuel injection that can easily be plumbed with AN fittings.
    Wiring
    Fuel Safe sells a wiring kit containing stainless hardware and nylon spacers to run electrical wires into a fuel tank. they are under a buck for a one screw kit.
