inline six id
Discussion in 'The Garage' started by 1979jimmy350, Jun 6, 2005.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    I have come across a free GM inline six and i have no idea what year it is. It has points, a removable intake. What else can i look for to get a better idea what year the engine is? The bellhousing has four bolt holes at the corners whould a sm 420 bolt up to this or do i need a older bellhousing?
  2. google
    google 1/2 ton status
    May 19, 2005
    805
    Arizona
    I really dont know much, but can't you just cross referance the code on the block?
  3. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    where would the code be located i know how to do all this stuff on a v8 but have no experience with a inline six i have no idea where i would be able to look up the numbers
  4. google
    May 19, 2005
    805
    Arizona
    Hmm, I dunno. All the info I got on mine came from www.mortec.com, but they only do V-8 chevy stuff I guess
  5. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    There is a pad right next to where the dist goes in the block. The engine ID will be stamped on it. You might have to scrape off a bunch of crud to see it.Its about 1" wide and 3" long.
  6. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    he's right...
    Yup--right next to the distributor is where the straight 6's have the code stamped...I have several books with listings if you post it here,I can check it for you.....seeing it has points means its a 74 or older motor unless someone put the point type distributor in it..the older ones are best,the motors without the integral head seem to last a lot longer than the ones that do,and the one barrel versions run better than the ones with the integral head and crappy 2SE 2 barrel carbs did... :crazy:
  7. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    As far as the bellhousing goes and it was OEM it will bolt up to a 420 just like it would any other tranny in that erra but you will need to verify that is has a 4-11/16" index bore instead of the 5-1/8" used by the 465's .
    If it would help you may want to post a pic of the engine and the pulleys that are on it. It could have a replacement block and it might help you if we could identify what year brackets/pulleys that it has on it so that it might be easier for you to get external parts for it.
    Good luck , Tom
