inline tbi sender and pump needed
Discussion in 'Rocky Mountain Region' started by supersize75k5, Sep 8, 2006.
  1. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    um..I finally got the 3/4 tons..
    finally got the sm456 and 205
    now I am at the fuel injection part before blazer bash and need the whole tank, or parts to put in my tank, this way its easy to hook up my return lines and such
    480-228-3218
    cash ready!
    :bow:
    shawn
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    There should already be a vapor return line going back to your tank that you can use as a return line or Moroso makes a splice kit to plumb a return line in the fuel fill hose. I used the Moroso kit with my injection to find out that there is already a line in place after I installed it.
    You don't need to swap fuel tanks for FI. I am using my stock tank in my K5. You just need to keep the tank 1/4 full or more offroad and 1/8 full or more onroad.
    I have only started to starve my motor once when I was on the street with less then 1/8 tank. I turned a corner and used alot of skinny pedal and the motor bucked a little bit until I got in a straight line again.
    Harley
  3. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
