Inner axel seal/Pinion seal replacement...10blt.ft
Discussion in 'The Garage' started by y5mgisi, Feb 4, 2006.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Tomorrow im going to be doing the balljoints, iner axel seals, wheel seals, and pinon seal on my 90. So ive got a few questions...
    1. Are the inner seals a big chore or are they pretty staright forward?
    2. Can I just remove the diff and put it and any shims back in the way they came out and have that work? or will the setup change?
    3. Do i need to get a new crush sleeve when I do the pinion seal?
    4. How do I know when ive crushed the sleeve enough if I do need a new one?
    Just hoping to get these answered tonight so i have as litle of hang up as possible tomorrow. Thanks
    oh yeah and does this look like an inner axel seal this is what the parts guy gave me...
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you have to pull both shafts, and the carrier, your preaty much left with the housing, so yea id say its a big job. but if your doing the balljoints, the only thing left is to pull the carrier, shouldn't be too bad.
    yes, as long as you put the shims back on the same side they came off of, it will be the same when back together.
    it is a very good idea to use a new one, it preloads the bearings. i have done it a few times and not replaced it. just mark the pinion and the nut, count the turns to get it off. put it back on the same amount of turns and line up the marks, then go 1/16" more to get the preload back.
    that looks like the seal.
  3. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Cool thanks man... el im to that point now. Allready got the balljoints done, so i just gotta drain the fron end, pull the diff etc. Thanks again!
  4. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    I have never replaced the crush sleeve. Just mark the nut and the pinion count the threads, pull it apart, replace the seal, put it all back together. I have done this too many times to count and have never had a leak. No need to replace the crush sleeve unless you love to work your ass off:eek1:
  5. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    ok sounds good.So b the looks of things i need to get a long rod of some sort and pound te old axel seals out from the nuckles and into the dif housing is that correct? man this is going to be such a royal pain in the ass.
