Inner or Outer Fender First (trim questions)
Discussion in 'The Garage' started by Impex, Aug 29, 2002.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    already had to trim my outer fendrs up flush to the inner fender (talking fronts) now im running 37s and they rub allot worse. i wanna cut them like steves so do i cut the inner fender first then cut the outer fender?
    Thanks GUYS!!!
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    i did the "UAV" cut job on mine and started with the inners. it was pretty easy, i would suggest that you use a cut off wheel for the job, letts you have more control and gives a good cut. in case ytou dont have the resty of the pics from Steves cuts i'll attach them.
    coloradok5.com/fendercut
  3. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Hey Josh,If you need some help cutting them fenders let me know.I'd start with using masking tape and deciding where you want the cuts.Are you just cutting the rear of the front fenders?a sawzall works good,but can kinda tricky.A cut off wheel is slow.Cut a little,you can always cut more.You will prob. lose your front fender bolt that is right behind the fender.It looks like you've already cut the inners,if not then I'd remove them to cut.Cut them right below the bolt that holds them to the firewall.Any Q's give me a call.Mike
  4. CK5
    May 19, 1999
    21,623
    701
    CO
    Man, that's an old pic, just cut them like this:
    I did the inners first, then tape off, a air saw workes the best, have fun.
  5. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Question for Steve Fox. Where did you get your roll bar and the tire carrier you put in the back of the truck?
  6. sapper
    Jul 11, 2001
    3,052
    NoVa
    now thats what i call sexy, when are you going to put together a artickle with some more pics?
