inner shaft on a 71 d44 same as inner shaft on 77 d44??????LINK TO PIX!!!!!!!!!!!!!
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by down4thakrown, Nov 9, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    got a shaft that has a 30/19 spline count. but the outer shaft bearing seal is differant. i think its outta of a 71 or somthing. i got a spare outter just need to know if the inner would work with a outer that fits a 77. and are the inner seals the same??
    pix here
  2. azblazer
    azblazer 1/2 ton status Premium Member
    Jul 20, 2003
    Grand Junction, Co.
    Since no one else will....
    1rst gen d44 shafts are different than the 2nd gen shafts-seals-ujoints.
    The seals are different as they seal differently and the u-joints are smaller.
    Goto the pick a part on 35th or 43rd ave south of van buren? Its been 4years since i have been there since we moved to colorado. Find a 73 -76ish gm 4wd with a d44 and rob the shafts out of it....then strip the backing plates - spindles - hubs - etc. and upgrade your d44 to the better sealing late model hubs....plus you get bigger u-joints. you might also see randy at driven auto and see how much he wants for the complete setup.
    Doug W.
    Kinda sorta ex amigo...
