Input Bearing for 205
Discussion in 'The Garage' started by lar300mag, Oct 11, 2006.
  1. lar300mag
    lar300mag 1/2 ton status
    Mar 17, 2006
    258
    TEXAS
    Does anybody have the bearing number to install a 32 spline input into a 205 designed for a 10 or 27 spline case, since I have 4 of these cases, i would like to see if or how long the load bearing holds up.
  2. tRustyK5
    Jul 23, 2000
    36,181
    1,388
    E-town baby!
    i don't have the number, but you will have to bore the case to install that bearing in a case that originally had a 10 or 27 spline input...
    Rene
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    A really cool guy I know named Marv , machined some parts that will let me run the 10 spline Chevy case , with the 31 spline Ford input , with no machining . I have both cases sitting on the garage floor awaiting usage . A few guys run this and long term has held up . I don't know about getting anymore , but I can take pics tonight to show you .
  4. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You do not have to have the case machined to run the 32 spline input. Lots of guys in AZ do it. The only problem is you have to have a spacer machined and access to the right part number bearing.
    Marv Springer might be able to tell you what you need part number wise and spacer wise to run the 32 spline input in a stock case.
    Harley
  6. lar300mag
    Mar 17, 2006
    258
    TEXAS
    205 bearing
    Now I have something to go on, Thanks...
  7. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Last time I bought the bearing, the # had changed. But they were still able to cross-referrence it w/ that 6010N #.
    Are you using an ORD doubler? If you are, I have the spacers you would need. If another brand, you gotta figure out what you need to keep the bearing in it's bore.
    Marv
