input on hubs wanted...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hayduke, Jun 28, 2001.
  1. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    hey there all,
    installed my warn prem hubs today and just want a little input on the installation...
    driver's side auto main part slid out fine, removed washer and slid in manual guts, dial bolted on fine and it passed the test when jacked up. other side's main auto slid out easily as well, but when the manual guts were in there wasn't enough room for the dial to be bolted on, so out everything came and i removed a small snap ring and spacer that was further back, put everything back in and it passed the test. drove down the street locked and in 4x4 and nothing exploded. what i want to know is if i should have removed the same parts from the driver's side as well even though it seems to be fine? and do you recomend using the snap ring on the outer part even though warn says it's optional?
    thaks in advance, i got all the install info from this site only, CK5 rocks and i love my new shirt!
    peace.
    HAYDUKE
    Insured By COLT, Policy #.357M
    <A target="_blank" HREF=http://haydukesk5.coloradok5.com>http://haydukesk5.coloradok5.com</A>
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I know this doesn't help you, but where did you get your Warns and how much? I am going to go to those shortly an dhave been price shopping. Curious about yours.
    85 GMC Jimmy, 305 w/TH700-NP208, 4" lift, 32X11.5 BFG ATs, 15x10 Eagles, Smittybuilt tube nerf bars and bumbers
  3. Hayduke
    May 9, 2000
    271
    NE Columbus, Ohio
    a buddy of mine took them off a rig he parted out, they cost me a case of beer and they look to be in fine shape...
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I don't use that snap ring as it's more of a PITA. Not necessary.
    Do I think you should remove those parts? Nah, do it the next time you've got the stuff apart.
    Tim
  6. Hayduke
    May 9, 2000
    271
    NE Columbus, Ohio
    that's what i was thinkin'
    thanks!
    HAYDUKE
  7. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Those little rings are unique to 10 bolts, I believe, but they are not necessary with the Warn hubs.
    A bit of advice: if you submerge the Warns, take em out and drain/re-lube them. Mine rusted internally.
    Lift It, Lock It, LIVE IT!!!
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The only thing you should see when the body of the hubs are removed is the nut that holds the wheel hub assembly on to the spindle. As far as any extra spacers being installed, I don't think they would hurt anything, though I'm surprised the hubs would slide in far enough to give enough room to install the snap rings. As far as the snap ring that goes on the axle shaft, on the outside of the hub, I would suggest using it along with the outer ring....just as an insurance policy. I've never had any problems removing either one of these.
  9. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    i got mine at advance auto. They are normally 80.99 for the premiums. I got my premiums for the price of the standards because of the idiot behind the counter. (61.99). Go with warn, they are the best IMHO.
    John
    '83 GMC Jimmy 4x4 ZZ4 Crate Motor
    '83 Chevy P/U 4x4 Sand Drag Racer, 578 RWHP
    '94 Impala SS
    '01 Chevy 2500HD w/8.1L & Allison Auto
  10. StoneyK5
    StoneyK5 1/2 ton status
    Jan 4, 2001
    472
    Birch Bay, Wa.
    When I re-lube mine, I use a white lithium grease, not axle grease that can harden from non use..seems to work for me..one of mine didn't work because of this and I drove about 40 mi. on the freeway with only one locked (in 2x4 just in case I needed 4x4) last winter..wonder I didn't loose the front end...
    83K5 Silverado
    What was that bump?
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Driving with one hub in!! I've done that before by accident. Not really all that bad on a front end if their's oil in it, I would guess.
    The outer snap ring really isn't necessary. I don't use it. The axleshafts can't move inward and outward very much anyway.
    Tim
