Input shaft oops
Discussion in 'The Garage' started by ssped, Apr 17, 2006.
  1. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    I pulled a tcase out of a burban saturday at the local pull a part and thought a 208 is a 208. so I did check the output shaft splines but I did not check the input. Dummaasssss. it is in the Truck and I am now stuck at work with my waif on the way to get me.
    I was chasing a bearing vibration that I developed after tearing both ujoints and drive lines out of the truck. it developes at freeway speeds. I hooked up the electronic ears and only heard noise in the tailshaft area. I know on our Rovers at work when a drive line goes it can easily take the tcase out as well so I picked up one. well no while I am sitting here ponering I pulled the old one apart so see if I could find the failure. All the bearings are smooth and in great shape but as I was reassembaling it I noticed slop in the chain. I spun the chain aznd the slop was taken up. There She Is. the Tcase Main shaft is bent. I found the vibration. I was worried that all this head ache and I was chasing a ghost. I will get her up tomorrow with another Tcase. or should i look for a 205?
  2. nemesis_pyros
    nemesis_pyros 1/2 ton status
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    Ok so you got 2 208's right? Just take your output shaft and put it in the other 208. Or put the other main shaft in your original case. I've had mine all apart and it wasn't that bad. Just be aware and don't "miss place" the bazillion needle bearings on the mainshaft.
  3. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    it is the main shaft that is bent. I have to pull it out anyways shouldnt I just get another one and slap it in? I did pull her apart and it does not look all that complicated. maybee i will look at her at lunch.
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    120 needles
  5. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Rain man.
  6. readymix
    May 30, 2004
    6,706
    26
    Nah, I just rebuilt one the other week. It was Ira's, and we did it in the desert so i distinctly remember counting them to be sure that we had not lost any of them
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you only loose the needle bearings if you pull the chain gear off the main shaft, you can swap inputs or swam mainshafts without worring about loosing any needle bearings.
    just take the snap ring off the front output to get that gear off then take the chain off. then your can remove the main shaft. VERY easy.
  8. nemesis_pyros
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    Ya i'm sure there is a better way than pulling it apart on the tailgate of a truck. But it still sucks putting all those little suckers back in.
    Little advice if you have to put them back in, we put a bunch of axle grease on the shaft and stuck them in the grease to hold them to the shaft untill you get them all back on.
  9. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    Did it
    :D I pulled her out and swapped all the best parts into one case. it really was pretty easy to do. I had also trashed the bearing between the input and mainshaft of the old tcase. It was super easy and just took a little patience. I had her back together and running in 2.5 hours. she ran really smooth on the way home and no funny noises. It also quieted down the Clunking from the Detroit. I knew there was a little to much play in somthin.
    Now back to lookin for a Dana.
