Inquiring About Dana 60's
Discussion in 'The Garage' started by k5bodyboy, May 6, 2005.
  1. k5bodyboy
    k5bodyboy Registered Member
    Oct 29, 2004
    26
    Hey ya not to new to ck5 but seeing how you all are chevy owners.
    What modle chevy truck had a dana 60 in the front and what is the king the king pin. And what makes it so special from a normal 60. Any info will be greatful. Also are they pretty well geard up or will I have to do a swap.
    proud owner of a 85 GMC Jimmy w/ a 355 producing 390 horse power and not quite enough torque thats why I here. Motor is backed my a home biult th350 w/ reverse shift pattern and shift kit, which powers through a partime 203 w/ custume twin stick kit made at home. The axels of choice where a mistake gm10 in the front and a wossie 12 bolt rear.Both equiped w/ 307 gears and a corp gm gov lock in the rear.
    Thankx
    K5 bodyboy
  2. k5bodyboy
    Oct 29, 2004
    26
    A man and his truck is a beautiful thing
  3. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    The Kingpin D60 can be found in a 1 ton Chevy truck up to '91. The normal 60 that you speak of has ball joints not king pins. As far as I know Chevrolet never used a ball joint D60. You aren't giving enough info to know what gear would be good for you.
    This may also help you http://www.m-w.com/
  4. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
  5. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    a kingpin is basically a big truncated cone of steel that the outters rotate about on a D60. The alternative, as mentioned, is ball joints which for withstanding years of offroad abuse, just aren't as good.
    j
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Kingpin vs. balljoint doesn't make much difference IMO. Its the ease of adding highsteer that makes the kingpin style advantageous.
  7. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
  8. Ryan B.
    Jul 18, 2001
    5,693
    CA
