inside the air filter there is a nother air filter???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MountainMan, Jan 8, 2002.
  1. MountainMan
    MountainMan Registered Member
    Oct 9, 2000
    89
    Highlands Ranch, Colorado
    Forgive if this is a no brainer, but inside my K&N air filter is another rigid filter that is part of the housing unit. I am thinking my K5 has CA emissions on it? anyone know what this second filter is? or does everyone have it?
    THX
    MountainMan Johnson
    86 K5
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I would think you mite mean the one that is in the OM air filter houseing it's like a PVC filter. But if your like me and have a 14in Crome thing you won't have one of those other filters I hope this help some.
    Eric
    <a target="_blank" href=http://cethern.tripod.com/erics-home-page-and-other-stuff/>http://cethern.tripod.com/erics-home-page-and-other-stuff/</a>
    AMSOIL Dealer # 529948
    Cethern@interfold.com
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    it could be the oil breather filter, keeps the oil from getting your air filter dirty when your engine starts getting blowby.
    my 2 sentaboz
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Its an emissions deal.Its part of the evaporative emissions control.There is charcoal in that element to trap fuel vapors that come up through the carb.Iv got it on mine.
    Some people shouldnt drive anything bigger than their head.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  5. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    My 86 Burben 'had' one of those. I removed it for better air flow. I still passes smog without it. It is a like a charcole canister like thing that is glued to the bottom of the air cleaner. Make sure you remove the air cleaner off the truck before you remove the fiter thing.
    <font color=red>....But I thought that sound was normal....!</font color=red>
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Same here. I had one, but removed it too. I have passed emissions without it.
    My Chevy isn't broken, its just out of gas.
  7. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Yeah, the last 3 replys hit it. It a emissions deal. Works just like a charcoal canister. It catches the fuel vapors that are left in the intake manifold after the engine is turned off, also catches the vapors from the carb as they escape. When the engine is restarted, it should release the vapors to be burned or "bleeds" the vapors to the real canister, to be burned later.
    Removal -should- fail most inspections. The other guys probably passed because it's a visual inspection. Meaning, the inspector only looks to see if everything is intact. They don't remove anything and check operation.
    But
    If the vehicale does fail, they could demand that you reinstall the charcoal filter. So If you do decide to remove it, don't loose it.....
    <font color=white>.</font color=white>Eric
    <font color=white>.</font color=white>Twizted
