instaling those add a leaf
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rick, Oct 31, 2002.
  1. Rick
    Rick Registered Member
    Oct 12, 2002
    16
    Bonifay, Fl.
    Is it hard to install those add a leaf springs and is it true they give you add least 2" of lift and were do they go on the bottom of the spring, middle, or top.
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    They are easy to install. Amount of lift is directly related to the thickness of the add-a-leaf, but most are more like 1-1.5 high. Make sure you have enough threads on your ubolts to add the leaf - if not you will need new ones. They normally are put on the bottom.
