Install a Cummins?
Discussion in '1982-Present GM Diesel' started by four_by_ken, Aug 9, 2001.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    I would like to install a Cummins diesel into a Suburban for my tow vehicle. I know it has been done. I just wonder how difficult it would be. Anyone have an idea?
    Reason being.... hate to say it, but a Cummins will kick a 6.2 or 6.5l butt.
    Ken H.
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    I have been researching this becuase I plan on doing this swap in the near future ( if I can find a motor and tranny for a good price ). Ive found out that Cummins makes a conversion kit to swap in the 5.9 6BT motors into an 87 and older chevy pickup. I havent called yet to confirm this nor have I gotten a price for this kit, but its probably well worth it. And you are right, the Cummins is far better than the 6.2 and can be built up to make some outrageous numbers on the dyno such as 1000 + ft lbs of torque and 400 + HP at the rear wheels. Keep in touch if you find out any more info about this swap.
    82 K5, 6.2L Diesel, sm465, np205, 14 bolt welded, 8 lug 10 bolt lock right, 410 gears, 35" Mud Kings
    SPEAK SOFTLY AND DRIVE A BIG TRUCK
  3. Cbody
    Cbody Registered Member
    Jul 6, 2001
    6
    Dawson, NE.
    Couple of questions first, what year 'burban, and 2 or 4wd, auto or stick? With those details I'll give a little more detailed info. I'm assuming that this is at least a 3/4ton correct?
    I had one in an '88 crew dually, but that was done back in the days before cummins made the adaptor for the GM trans, so a 727 was used (2 wd). Some crappy pics at
    http://www.kenalbin.com/88chevycummins.html
    Jay
    http://kenalbin.com/jay.html
  4. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Yes, it is a 3/4 ton. 14bolt rear, 454, 400 trans, 208 xfer.
    Doest have to be a Cummins, but that is most common.
    Ken H.
  5. Guest66
    Guest66 Registered Member
    Jul 8, 2001
    50
    Utah
    wound i be able to install a cummings into my K5? i have a 6.2 and i my dad has a 5.9 and i love it. Thanks for whatever info
  6. josephn
    josephn 1/2 ton status
    Nov 3, 2000
    138
    Utah
    I would also like to know if i could install one in my k5.
    1982 6.2L Diesel K5 Blazer, TH700, 31 inch tires.
    Fire ALWAYS makes it better.
  7. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    Sheesh... It's a full size GM truck! You can stick darn near anything under the hood of these things! :-D
    Personally, I'd go for a CAT under the hood, if I ever replace my 6.2L diesel. It's either that, or a massive rebuild and lots of Gale Banks turbo lovin' for the 6.2L!
    Dan Oglesby
    1984 K10 Blazer, 6.2L diesel, 700R4
  8. Double_T
    Double_T Registered Member
    Jun 28, 2001
    71
    Orygun
    Anybody remember the "Four Wheeler" issue where the guy installed a somethingsomethingsomething Cummins in his jeep? What's up with that. Does Cummins make several different "smaller" engines? Hell no this ain't a stewpid kweshtun!
  9. 82GMC
    82GMC 1/2 ton status
    May 14, 2000
    553
    Seattle Washington
    Hey Doublt T, Just go check out Cummins web site, <a target="_blank" href=http://www.cummins.com>www.cummins.com</a>. You'll find they make just about anything diesel, From 2 cilender power generaters, To big massive 12 liter truck engines!!!!
    [​IMG]Inline 6's are cool[​IMG]
  10. Double_T
    Jun 28, 2001
    71
    Orygun
    Thanks 82, for the info.
