Install York compressor on 87 Blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ds350, Mar 22, 2002.
  1. ds350
    ds350 1/2 ton status
    Jan 26, 2001
    190
    Bay Area
    Any advice on linking up a York compressor for onboard air, if all of the accesories are being used...P/S, smog pump, Alt, A/C. My blazer has the v-belt setup, and adding the york will be interesting, since all of the pulleys are in use. Has anyone done this while keeping all of the accessories in place....especially A/C?
    Danny
  2. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    I am interested also on this topic for my 87....
  3. MudTruk
    MudTruk Registered Member
    Jul 21, 2001
    32
    Norman, Oklahoma
    Have you guys checked out the York compressor install in the technical section? It was losts of help when I was considering my options. Check it out!
    Pete
  4. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    I just put onboard air on my 79. i love it. it was pretty easy to do. i got mine off of a ford bronco and took the mount along with it. i then drilled a hole and put it on the ps pump mount. then i welded a cheap lil plate thing that goes to the header bolt. email me and ill send ya pics.
    NITRO
  5. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I'm trying to remember where I read it, but some one used a serp style alternator pulley on it. Not sure on your mounting options, but I have also seen people weld pulleys together to get the job accomplished. Check around on onboardair.com and rockcrawler.com cause I know I saw a couple articles when I was looking at york ideas. Wish I could be of more help.
