installation issues
Discussion in 'Audio' started by HELLBENT DESIGNS, Jan 2, 2006.
  1. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    looking to do the stereo install in the 67 gmc. a bit more than a basic system ( 4 amps, multiple active crossovers etc.) the local stereo shops are crap:mad: seems like if you are not a high school kid with moms credit card or doing a high dollar home system you are not worth the time to talk to! i can do the basics such as wiring and mounting stuff but the boxes for subs (JL10w7) are more than i want to deal with:doah:
  2. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    Did you have a question? :confused: :D
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Yeah, If you need a box design, just let me know some specs and the room you have to work with.
  4. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    truck is a 1967 gmc incab gas tank relocated)the sub is a JLw7 10" manual says 1.25 cu. ft. recommended net volume. also mounting depth 8" overall 9.63" grill clearance 2.25" one time i spoke to an installer that said he could fire the sub down and incorporate it into a console? the space i have to work with is about 13" between the bucket seats and the floor up to the floor shifter. the seats touch the rear of cab so only room for amps. ever worked with a downfire sub box? i have no woodworking tools but work with a guy that builds furniture so he could do it thanks :D
  5. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    any help audio guys?
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I used too own a 78 C30 crew cab. Anyways there isn't a whole lot of room behind the rear seat. I had a custom box build and 4 10" subs. So I would think you'd be able too have a box behind your seat sence you've relocated the gas tank.
  7. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    behind the seats are not an option! i am 6'-4" and having the drivers seat touching the back of the cab still leaves me kinda cramped:mad: so if the sub box touches the rear of cab between seats it can't go too far forward cause that will hit my right elbow:(
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    What about under the seat ?? Any room there ??
  9. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    not a real good pic but only maybe 3 inches under seats:doah:
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Well, just a thought.
  11. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    thanks bro! every idea welcome:waytogo:
  12. chevyin
    Sep 14, 2005
    1,324
    Pismo Bch CA
    It sounds like your only option for the subwoofer enclosure's location is the center console... am I right? :) Take some rough measurements with a tape measure, some quick math with a calculator remembering to factor in for wood thickness (3/4"mdf preferrable), and you should have a pretty good idea how the box will fit. With 13" between the seats Im sure fitting 1.25 cubes won't be difficult.
    Once you've determine the approximate size (and are sure the thing is gonna fit the space), you can decide how fancy you want it. For example, fiberglass boxes are always nice, invert the sub so the motor sticks out, incorporate an arm rest, etc.
    Downfire is a possiblility, but Im not sure I see the advantage. Downfiring works good on convertibles and open-air vehicles, but otherwise more traditional mounting wethods usually work better. I guess it would help protect the sub, if that's a concern.
  13. chevyin
    Sep 14, 2005
    1,324
    Pismo Bch CA
    And, if you're hardcore, there's always the Roof-of-Boom (tm) mounting method:
    :eek1: :D
  14. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
    yup looks like console mount is the best way to go. sitting in the drivers seat a 14" high console would be ok ( 13" for sub and 1" for armrest.) main reason for downfire is to protect the sub (and hide it) i have almost 2ft lengthx13" wide to pick up the airspace needed.
  15. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    :haha: :haha: Now, that is one of the funniest pictures I've seen in a while. :haha: :haha:
