Installed 3rd Brake Light
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beefcake83, Apr 10, 2001.
  1. beefcake83
    beefcake83 1/2 ton status
    Jun 24, 2000
    240
    Alaska
    Just installed an LED third brake light from a '97 Burban on my Jimmy. Looks sweet! I'm working on a pic.
    Gary Graham
    '83 GMC Jimmy 350 'Beefcake'
    Eielson AFB, Alaska
    Metallica & Mountain Dew
    http://community.webshots.com/user/beefcake83
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Cool! I wanna see pics! Do you ever take the hard top off? If so, do you just disconnect it?
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  3. beefcake83
    Jun 24, 2000
    240
    Alaska
    Yeah, it has a diconnect just like the front dome light... a few seconds to undo and the top still comes off. Makes the Beast look newer than an 83, which is my intention.
    Gary Graham
    Eielson AFB, Alaska
  4. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    Get some pic's up when you get a chance. How did you route the wires inside?
    '89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".
  5. beefcake83
    Jun 24, 2000
    240
    Alaska
    I did tonight... see them at: http://community.webshots.com/user/beefcake83
    I snaked them inside from the top under the light base like on the suburban.... took a hole saw and made a hole at the base of the left back corner inside of the topper similar to the one that the dome light wiring comes out of.... ended up making a second hole almost in the upper corner too because of inside structural interferance stopping the wire feeding. Then put in a disconnect connector so the topper can still be removed in a hurry. First tapped into the left tail light and found that it flashed with the left turn signal on... duh! Than tapped into the white wire off of the brake light switch.
    Gary Graham
    Eielson AFB, Alaska
  6. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
  7. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    <A target="_blank" HREF=http://community.webshots.com/user/beefcake83>http://community.webshots.com/user/beefcake83</A>
    74 Blazer
    Kashmir
    Zepplin
