iNSTALLED 4" LIFT BUT.....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by santana, Jun 30, 2003.
  1. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    iNSTALLED 4\" LIFT BUT.....
    For the life of me I cant figureout how to remove the steering knuckle, I removed the 3 nuts that fasten it to the axle but it doesnt move.. /forums/images/graemlins/angryfire.gif Is there a trick to this or a tool I kneed /forums/images/graemlins/ears.gif
    Jerry..
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: iNSTALLED 4\" LIFT BUT.....
    Are you talking about the steering arm? Big F'ing hammer
  3. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    It's been a while since I did it, but I think you can jack the weight of the vehicle or axle on it and then just pound like crazy with a BFH.
  4. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    Big F'n hammer huh! /forums/images/graemlins/grin.gif Is it just stuck and needs to be banged off, I cant even get in a position to get a good hit without hitting something else /forums/images/graemlins/eek.gif.. Does it matter where I hit or do I have to hut upwards?? /forums/images/graemlins/ears.gif
    Jerry...
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Hit it up and down, left and right, and front and back until it finally pops. (There are cone washers around the studs that you're trying to pop free - if you can pry them out or get a screwdriver and spin them, then it should be easy after that)
  6. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    Correct me if I'm wrong, but can't you also loosen the nuts and drive around the block a few times to pop it free? /forums/images/graemlins/thinking.gif Being careful of course /forums/images/graemlins/thumb.gif
  7. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    Got it! Thanks fellas. /forums/images/graemlins/thumb.gif
    Jerry...
