Installed my sway bar disconnects!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Apr 5, 2001.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Check out the pics.
    http://mudfrog.coloradok5.com
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    There should be an L-Shaped bracket that is mounted between the bumpstop and frame. Then you use one of the pins to hold it up out of the way by sliding it through the sway bar and the L-shaped bracket.
  3. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    Cool. I just did mine about 15 mins ago. Got home from work and there they were in the mail. Took about 20 mins to get them in. ORD makes some top quality stuff. I've been rolling in my recent 6" lift without the sway bar connected... lots of body roll on turns. The steering is tight now that everything is installed. As for when the bar is disconnected, there is a bracket that mounts to the pass side bumpstop. The bar can be hooked up to the bracket using the same pins. The bracket should've came with the kit but it looks like you got them used. Check with whomever sold them to you.
    Rod
  4. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Does it handle any diffrent on the pavement??????????
    Become one with nature............Then marinate it..
  5. Grim-Reaper
    7,385
    Atlanta
    As good if not better than stock all things concidered!
    The stock sway bar on a lifted truck causes some weird bump steer. The bump steer was worse with the bar without disconnects than it was no bar at all. With the disconnects fixing the angle and allowing some movement foward and back it makes it awsome. I have a stock 79 and I would say my lifted 75 rides better and handles almost as good (the higher CG is only reason it doesn't). Over all I'm Very pleased with the product. Thats 2 for 2 with ORD products. I have the steering brace also and I feel it is well worth the money also.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  6. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    See I can't really say it handles any better because I haven't received my lift yet. But I've heard of a few guys using them on the stock vehicles, so I figured what the heck. I haven't really noticed much difference so far. Maybe a tad bit more sway but nothing bad.
    I was wondering what that L shaped bracket was for LOL. Anybody got a pic of the bracket installed that I could see?
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  7. Storm Trooper
    Nov 24, 2000
    4,640
    Just installed mine last night, had a little trouble with the aftermarket sleeves from Energy Suspension being too thick.
    I didn't have a 9/16 drill bit but found that a 1/2" bit with some sand paper wraped on it worked great. I also drilled a couple small holes in the lower part so I could use my needle greaser to add some lube. Just put on the EZ-ride front springs & greaseable bolts the night before. DAM dudes, if you don't have greaseable bushings on all your springs I think it will KILL any ride quality. I also added the heavy duty shackles from ORD. Ym old shakles you could hit with a sledge and they wouldn't move! My truck rode like a rock. I'm going to Moab next week and can't wait to try it out [​IMG]. I just have to do the DS rear spring bushings and I'm done. CAN"T WAIT&gt;&gt;&gt;&gt;&gt;&gt;&gt;&gt;&gt; grease your stuff!
    [​IMG]<font color=red>Rid'in High In My K5[​IMG]
