installing 14bff ?
Discussion in 'The Garage' started by Cole, Nov 27, 2006.
  1. Cole
    Cole Registered Member
    Jul 7, 2005
    13
    Kentucky
    i just finished putting the 14b in my 3/4 ton silverado, and the drivers side leaf spring bolt doesn't sit properly in the mount on the axle. there is a very small gap but the bolt is in the hole. should i grind the bolt down a little bit or will it be alright.
    Thanks in advance,
    Cole
  2. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    you want that to be very tight. if it has a gap because the threads stick to far out of the nut too far, then yeah grind them down. if that is not the reason then you have other problems.
  3. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    the center pin hole on the axle perches 99% of the time are full of rust and dirt. take a grinder bit and blast that junk out. or a hammer and center punch will work also. all parts of the spring to axle need to be flat as possible to seat the best.
