installing a B&M Megashifters
Discussion in 'The Garage' started by adamforsythe, Sep 3, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
  2. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Not really a pain to install....
    Lotta guys talk bad about them... but I like mine....
    Only complaint is that when you get vertical, the "T" shaped " Reverse lock thingy can hang up :crazy: cuz it depends on gravity to fall back down...
    I need to install a spring on mine.... :laugh:
    Marv
  3. destinbeachman
    destinbeachman 1/2 ton status
    Aug 31, 2005
    365
    Florida
    Yup,I like mine too.You can just slap it back to drop a gear and put some ponies down and then give it a slap forward to put her back.The install isn't much-you'll have to drill a few holes to mount the baseplate on the floor,open up a small hole for the cable up near the front of where the baseplate mounts,and finish up by connecting the cable and adjusting it and running a lead from your light switch and one for your back up lights.You'll love the way it fits your hand and gives you good control over your transmission.
  4. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Cool, Do I have to do anything do make my back up lights come on? I was told I will need to run wires to make my back up lights work and to splice into the (N) safty switch.
  5. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    It'll all be coverd in the directions. I believe switches even come with the B&M shifters for neutral safty and back up lights.
    Eric M.
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Piece of cake to install. Good instructions and they come with micro switches too. I used a relay too for my back up lights as they're kinda bright! :D
