Installing a B&M Transpak into a TH350
Discussion in 'The Garage' started by adamforsythe, Jan 17, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Is it hard to install a B&M Transpak into a TH350? My tranny does not like to shift when I kick in the 4 Barrel so I think I will help it out by installing one of these kits.
    Adam
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the th350 is vacuum controlled as far as when it shifts. with the throttle wide open your not getting enouhg vacuum to make it shift.
    i have never put a B&M kit in and probably never will. i feel the Transgo kits works better.
  3. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    There pritty simple just take your time and read the instuctions, it sounds like it would be all intense but its not. they come with a 24 hour hotline for any help you may need, never called it so i cant tell how good it is.
  4. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    so even with the Transpak it wont shift any better when I really get on it?
    Adam
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    most likely not. an adjustable modulator would be a better choise.
  6. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Where would I get one?
  7. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    What exactly is the problem?
    If it's just the kickdown you need to adjust your detent cable.
    If it's the shift points an adjustable modulator can be picked up from B&M, Hughes, TCI, or your local transmission shop. It just has a flat head adjustable screw in it that you can adjust the shift points with by turning in for a harder later shift or out for a softer earlier shift.
  8. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    The truck seems not to want to shift from 2 to 3 gear. Fluid is mint, tranny is new.
  9. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Well where did you get the new tranny? If it's a local shop take it back and have it adjusted.
    How does it shift through the rest of the drive range. Is the problem only during full throttle? There are several things it could be.
    Information number 6, we want information.
  10. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Ok I will give you some info on the truck and then tell you what is going on.
    This is a 1985 K5 Blazer with a new tranny Th350 , engine 350 4 bolt, 600cfm edelbrock carb and a few other things are new.
    When I am just driving the truck shifts real nice. But if I get on it any first to second gear is fine but once the tranny gets to the point where it should shift into 3 from second it takes a long time. In fact I have to let off from the gas to get her to shift.
    It may just be the carb, or I may just be a little to anal about how it runs.
  11. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I'd take it back to the guy who built it and have him make it work right.
    I would not install a B&M shift kit in any vehicle I cared about. Most auto trans guys won't either, they use TransGo kits.
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well just driving it around it shifts nice , that normal sounding .
    When you get on it , it won't go into 3rd until you let off the gas a bit , thats normal sounding also . In all my Chevs ( Chevelles , lagunas , montes , truck ) it is/was like that :k5: :k5:
    You want it to stop...........disconnect the kickdown cable and get a ratchet shifter , kick it down or prevent an upshift on your own :)
