Installing a Breather
Discussion in 'The Garage' started by aknight_sa, Nov 19, 2006.
  1. aknight_sa
    aknight_sa 1/2 ton status
    Oct 14, 2005
    305
    Saudi Arabia
    hi all,
    is there a reason why someone will install a breather on the valve cover rather than routing a hose to the air filter?
    when should that be done? and are there any benafits?
    Thanks,?
  2. badmix
    badmix 1/2 ton status
    Nov 7, 2004
    4,205
    60
    West Virginia
    Sure. Im runnin open element air filter assembly on my carb'd 84 K5, once you take off stock air filter box, ya have to do something with the breather.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I've run breathers on the rockers like Madmoocow...I mean badmix says with an open element filter but when it's hot and your moving slow you can get quite a lot that 'hot oil smell' in the cab.
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    There's another reason for me- In a rollover, if you route the breather hose up and around the motor to just below the other head, you will not puke oil from the valve covers when you are upside down.
