Installing a chip in my 95 tahoe
Discussion in 'The Garage' started by atlantak-5er, Jan 19, 2004.
  1. atlantak-5er
    atlantak-5er 1/2 ton status
    Aug 20, 2003
    225
    Atlanta, GA
    It says to put the chip behing the glovebox. Do I just take the glovebox out? Or can i get to it form the back?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You have to remove the glovebox. Then it's pretty easy to see the ECM. It's not so easy to get your hands in there to remove the screws holding the ECM to the bottom of the dash. Once you have the ECM removed, just remove a couple of screws to access the PROM chip and you're nearly finished. /forums/images/graemlins/cool.gif
    Be sure that you disconnect the battery BEFORE you begin! And double, even triple-check that you insert the new PROM so that it is oriented the same way as the old one. There's a notch in one end to designate where pin 1 is. If you insert it backwards you'll get a small, brief smoke show when you reconnect the power, as the chip burns itself to smithereens. /forums/images/graemlins/eek.gif /forums/images/graemlins/frown.gif
  3. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    yes take the glove box out and the ecu box is held in with clips. I have a HyperTech stage 2 chip in mine but idk if yours is a 95 do you have the vortech motor or just tbi? b/c its in a different spot on the vortechs or at least i think so but mabey not. /forums/images/graemlins/thumb.gif
  4. atlantak-5er
    Aug 20, 2003
    225
    Atlanta, GA
    Mine is not a vortec. Its the last year for the TBI motor. I have a jet stage II chip.
    Thanks for the info! I'll be sure to double check so I dont fry my chip!
    Did you guys notice a big power increase? I'll let you know how mine is tomorrow.
  5. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I will be interested to hear your results as I have a dog of a 95 Yukon that is my daily driver.
  6. fly_n_hi_yukon
    fly_n_hi_yukon Registered Member
    Jul 8, 2003
    44
    Strange Range, MI
    Vortecs don't have chips, you have to flash the ECU with a Hypertech Power Programmer 3 or similar.
    Some of the late '95s got the Vortec 350s, but the vast majority were TBI.
    I had a HyperCrap stage I in my Yukon and it ran like crap. I got it used though for $25, so who am I to complain? Oh, and BTW, get used to filling up with premium fuel, because you'll kill your engine pretty quick on 87 octane.
  7. atlantak-5er
    Aug 20, 2003
    225
    Atlanta, GA
    Well just installed the jet stage II. T-stat to go in tomorrow. The results are impressive. My brother has a 96 4 door tahoe; stock w/ the vortec motor. Before, he would pull me from the get go and continue to pull away.
    I have a k&n filter and Flowmaster 3" in and 2 2.5" out exhaust system, every thing else is stock. Now with the chip installed, we were nearly dead even. I actually started pulling away around 50-60 mph, but we ran out of road.
    At idle, it runs just as smooth as stock. Of the line it feels the same until it gets to about 2,500 rpm or so, and it begins to pull a good bit harded than it did. Seem like it added little or no torque but added a good bit or High RPM Horsepower (i'd say 30hp). On the highway on my way to work is where I noticed the biggest difference. It gains speed much quicker and with less of a struggle.
    Overall, I am happy considering I paid $159.00 for the chip at JEGS and everywhere else wanted $215.00 or more. It took me about 30 min. to install it but I broke the lower hinge tabs off my dang glovebox when trying to remove it, so that will probably cost me $50-60 bucks. For those of you who do this in the future, take the limiting strap off the glovebox door and let it come down and it should slide out when the door is about 120 dergees open!
