installing a heater - have questions
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by rrent, Nov 20, 2002.
  1. rrent
    rrent 1/2 ton status
    Jun 10, 2001
    174
    Round Rock, Texas
    Greetings, all - I picked up a factory heater for my Blazer. I got the outside part with core, inside air controller and controls with cables. How was this hooked to defroster and any/other vents? Big plastic preformed tubes? My truck had chrome ball vents on the sides of the dash and one in the middle - was this an AC truck? Is there an assembly manual type pic of this setup anywhere onthe net?
    thanks in advance
    Ronnie
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Your truck was an A/C truck. If the set-up you bought is not an A/C set-up, you will have no hoses going to the ball vents, or the center vent in the dash. You will also need the non-A/C version of the control lever assembly. On another note though, the cut outs in the firewall are not the same for A/C and non-A/C trucks of this era. The vents are connected from the box that has the heat / defrost deflector flap with hoses. The hose kits can be purchased very inexpensively from many of the parts vendors that sell stuff for these trucks.
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    they were connected by black dryer vent tupe tubes that always come off. i dont know of a pic on the net. i have a 74 fsm that i might could scan if its got one. if you look on the firewall behind the glove box yopu will see 2 1 1/2 holes or so that had the ac lines through them.
    nathan
