Installing an Aluminum Intake
Discussion in 'The Garage' started by Poohbair, Feb 9, 2004.
  1. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I was going to install an aluminum intake on my car yesterday (a Ford, I know...I know...)and them motor has 4 studs and the rest are bolts. The studs are not long enough to reach thru the intake. So, do I have to put in longer studs or can I just use all bolts and no studs? Do I have to use actual intake bolts or can I just go to the hardware store and get some grade 5 bolts or something.
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    You don't have to use the studs. They just help you line the intake up. You can just use regular bolts, just use washers under the bolt. And with ANY aluminum intake, go back and re torque after a week or so.
  3. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    Dont forget the Anti-Seize on any steel part that touches the Al
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Grade 5 bolts will be fine. Spec on a chev engine is only around 30 or 35 foot pounds.
  5. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Thanks alot guys, I appreciate the info. Oh, in case anyone was curious it is a 68 Cougar that I am beginning a resto-mod on. I am hoping to get this thing back together and running good by the end of the week.
