installing an inertube in a tubeless tire
Discussion in 'The Garage' started by Seventy4Blazer, Nov 11, 2002.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    what do i have to do to SAFELY put an innertube in some hummer tires? talc powder in it like on a bicycle? i know i have to patch any holed the tire has. i have a set of hummer tires that have holes in the sidewall. i want to put them on my wifes 76 jimmy. in a safe way i want her to be able to drive down the road on a day to day basis. grease the tubes with a waterbased lube? or just throw the tubes in there and mount the tire?
    i know somebody knows... LEMME KNOW PLEASE!!
    he he, Grant
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Just my opinion, but I wouldn't put a tire on my wife's car that had a hole big enough in the sidewall to need a tube. If you are going to do it, just use talc. </font color>
  3. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    no no, theese are cactus hole. nothing bigger than a large pin hole. i am going to try to patch them, but i just want to know if it doesnt hold that i have to go "find" new tires.
    thanks for the help. Grant
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    they used talc on mine and then my rims were crap so they wrapped em in duck tape to keep the rough spots from rubbing a hole.
    just my .02
    nathan
    69K5
  5. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    k, just out of curosity what size tire did you do it on?
    Grant
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    just a 33. i dont have a lift yet so thats all i can fit. They used a tractor innertube. just fyi. it had kinds long valve stem 2 1/2 or 3 " easy to get to though.
    nathan
  7. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    yeah, thats what i am looking at for tubes. how long has it lasted?
    do you think it is safe enough to drive on for a long period of time?
    Grant
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Anybody turns up a reasonable priced tube for 42x15s, let me know. They want around $70 each for the ones I found.
  9. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    he he he, russ... HA HA HA, your a smurf again... /forums/images/graemlins/shocked.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/ignore.gif
    sorry man..... what size you looking at? i am going to mount the tires tomorrow. i need one more, then i have the set i need. 37's in back, 33's in front... yeah, itll look funny, at first.
    Grant
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Heh, yeah... I just found that out when I couldn't get in the Bloody Knuckle. /forums/images/graemlins/frown.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/crazy.gif
    Has it been a year?!! Wow! Oh well, I'm out of town for the next 2 weeks, I'll probably re-up when I get home...
    As for the tubes, I need anything that will hold up to a 42x15 just enough to get it off the trail. I would buy 2 if found at a decent price. I'm running on borrowed time, even 42" TSLs can loose a side wall once in a while... I also need to get some boot material just in case. I've got wire, can make do for an awl, but without a tube I'm going to be SOL if/when it happens. /forums/images/graemlins/laugh.gif
  11. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i have been driving on mine for a year now. I had em rub 2 leaks but they were slow leaks. i patched it with tape and no problem sense.
    nathan
  12. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    ok, thanks. so far i got one mounted. lets see how well it holds pressure.
    Grant
  13. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    where did you find these tubes?
