Installing AutoMeters, How to keep the check engine light?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Sep 10, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I am going to finish my install of new AutoMeter Ultra-Lights this week...Now, all the facotry gauges are on the circut board...All the auto meters are going to be wired individually...But how can I keep the check engine light and the seatbelt light? Thanks a bunch...
    Chris
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Should just be a switched positive coming from the sensors to the printed circuit board via the wiring harness, and the common negative in the circuit board. Just find the right wire in the harness (I traced back from the lights and gauges to the harness to be sure that I got the right wire), then hook up any 12v light + to the wire from the sensor and - to ground.</font color>
  3. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    You can use two common type indicator lights and wire them in place of the dash panel lights. I think the "check engine" light is fed power from the printed circuit board when the ignition is on, the ground side goes to the ecm, it uses the ground to switch it on and off.
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Any ignition power source will work. The ground side of the SES goes to the ECM. The SES on my 71 is an LED in the dash that I wired into the dash light circuit.
