installing brake lines
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sapper, Sep 14, 2001.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    putting on the extended lines tommarow. the package didnt come with any instructions and its got some washers (2) a couple plastic horeshoe clips not sure what they are for. any suggestions would be great. thanks
    <a target="_blank" href=http://coloradoK5.com/gallery/Pauls89K5>http://coloradoK5.com/gallery/Pauls89K5</a>
  2. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    What you have sounds like an incomplete kit. You should have 4 copper washers or aluminum(sp?) if you got 2 hoses. Or 6 washers if you were give 3 hoses. I put on some extended brakelines a month ago. With no problems.
    The trick is Have rags and plenty of them.
    1. disconnect the nut on the inside of the frame (easyest through the hood.)
    2. be sure not to strip the nuts.
    3. take off the hose off of the caliper I think 7/16
    4. You will notice that the connection on the caliper has small washers on them, that is where the new ones go. one on each side. try to keep the fluid off of you tires It may mess them up.
    The zip ties are to hold the break hoses to the shocks body.
    *NOTE Break fluid KILLS paint and cloths*
    Good luck KEN
    DANGIT it's not a bronco!
