installing cab lights
Discussion in 'The Garage' started by bigbadchev84, Jun 25, 2006.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    has anyone installed cab lights on there rigs? i like the look of stock ones how hard is it to install the wiring? thanks
  2. shockline
    shockline Registered Member
    May 10, 2006
    51
    Powhatan Virginia
    My stock lights where not doing the job well. I got a set of aftermarket lights that swivel and have two lights. I had to enlarge the hole in my fiberglass in the rear but the one on the front fit right in, i just had to drill new screw holes. I used the existing wiring and they work great.
  3. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    I did in an older ford truck that I had. It was rather easy. Just remember, measure twice...cut once. :D
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The stock wiring goes down through the A-pillar and plugs into the fuse-block ;) Try not to cut through both layers of roof :doah:
  5. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    what is the best way to fish the wire through?
  6. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    TTT
    Im gonna need help with this. Is the two layers of metal hollow or is there insulation in there? Do I ground it to the top or do I run a common ground down with the power wire? I also want to know about fishing a wire down the a-pillar.
