Installing Cam Bearings?
Discussion in 'The Garage' started by kennyw, Feb 13, 2004.
  1. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I am taking the cam bearings out of a small block chevy with a tool that works somewhat like a slide hammer. Should I just start at one end and keep knocking them out one on top of the other?
    I have a good short block that is still assembled and I would prefer not to pull it apart if possible.
  2. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Yes, just knock the cam bearings out, start from the front and work your way back. Your also going to pop out the plug in the rear. Now installing is important. You have to have your oil holes lined up correctly, not to mention the cam bearings in the right order. Looking at it from the front, the oil holes should be at about the 4 o-clock postion.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Definitely pay someone to do this. I've done this project, but only once, and I'd never do it again. Too much margin for error here.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I concur. Have the shop that does your machining install them . Then you could just go home with the specs and all the correct sized parts and have a blast /forums/images/graemlins/thumb.gif
  5. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    I only paid $25 to get mine done.
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    position is VERY important. They are numbered.
  7. kennyw
    Jun 9, 2002
    13,224
    94
    My friend finally found the instructions for the tool. The way the sizes are stepped you cant pull the larger outer bearings thru the smaller inner bearing holes! No reason to pay someone to do this when I have the tools and time. Once I had the instructions it was easy to tell how it was supposed to work.
    New bearings are now installed and all the oil holes are lined up and I didnt even need to pull the pistons, conn rods or crank. /forums/images/graemlins/thumb.gif I'm not doing any machine work on this motor just putting in a new cam, cam bearings, lifters and gaskets to freshen it up a bit.
  8. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Good stuff, cam bearings arent hard to do. just make sure you measue the clearance between the cam bearing and cam, i have had to ream some bearings out to give proper clearance. to tight and the cam will seize up.
