installing drop blocks for sway bar
Discussion in 'The Garage' started by NEK5, Dec 15, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Ok, I was giving these drop blocks for the swaybar by a member here that i bought the ORD discos from. So I gave them to my buddy, who has a 4 inch lift, and yesterday we tried to get the to work but we couldn`t get the mounts to line back up, and from the looks of it, it actually looks like it will bind it up even more:confused:
    These are the blocks here..
  2. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    my drop brackets are angled with offset holes. moves the bar down and back to compensate. Those are totally differant.
  3. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    got any pics?
  4. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    for everything to line up you either need ones that move the sway bar back or drop it the same amount as the lift. the problem is that GM should have put some type of endlink on the swaybar. your springs have shackles so that the springs can lengthen as they are compressed. the sway bar needs something too. As the spring compresses the sway bar will keep the spring and axle from moving backwards causing bind. throw the blocks away and get another set of disco's or ditch the swaybar.
  5. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    yes, but unfortunately they are at home and I am not. I'll try to find a pick where I bought them.
  6. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    ok, I doubt that he`ll ditch the swaybar. I`ll see what he wants to do...
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    4 pieces of stock with holes drilled , some extra bushings , and a couple through bolts , Copy the disco kit kinda that way . Hell you could use some hitch pins on the bolts instead of nuts .
    I would find the discos myself . Easier that way .
