Installing emblems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 6.2 man, Mar 25, 2000.
  1. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    I picked up the Blazer emblem for my local GM dealer for my 83 Blazer ( the ones on the front fenders ) . I didn't have to remove old emblem to install new one (orig. emblem got broke off ) I figured I would have to remove fender to install . Anybody got any tricks or secrets to installing the emblem .
  2. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    STOP you dont have to take off the fenders just get some 3m double sided tape (like the pinstrip width tape) apply it around the entire edge of the emblem. peel off the backing tape and viola. stick the pins in the hole and there you go its on. trust i take a collision repair course at a high school career center, done it lots of time, what do you think the new factory cars come with special high dollar stuff nah just doulbe sided tape. hope this helps.
  3. Nomorerust
    Nomorerust Registered Member
    Feb 18, 2000
    25
    Penna,US
    I ran into the same problem.Went to an auto body "supplies" shop and purchased special clips which are inserted into the original holes and then the emblem pushes into those.
    You will need to use a reeming tool(works better than a drill bit)to SLIGHTLY enlarge the hole for the proper size than touch up with paint.After inserting the reem tool and aquiring the correct diameter to fit these clips wrap tape around the tool itself as a guide for the other three holes.The emblems will not come out!!!!!!!
    CJ
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I agree with badboti. I've had buds that have gotten ahold of either the two-sided tape or a special kind of butyl that windshield guys use, and basically just press the emblems on. It's worked for one guy for over 5 years........
  5. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,956
    249
    Released from Pueblo, told I belong in Southpark
    These clips are called barrel clips and expand after insertion and last forever. At least until the next emblem gets broken off.
  6. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    I wonder if any of you have ever removed the long emblem-plate on the tailgate. Do you have to go in from the back/innside or is the plate pressed on with clips??
    I have this litle dent there, I imagine I can hammer out from behind.
  7. bad_bo_ti
    1,027
    OhiO
    know that one too. gotta go in from the back, let the tailgate down, take the panel off then roll up the window supporting it with something so it doesnt fall out. then there are little self threading bolts just take those off and it is off, i have two of these emblems by the way, if anyone wants to purchase one off me. aint putting one on the new gate after all the crud i found behind my old one.
  8. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Check with www.3m.com and look for the sticky tape. They have several different types. And they will send you samples if you ask. It just so happens that the samples have more then enough to replace all the emblems on a blazer. Ain't it great!
    <font color=green>Eagle86K5[​IMG]
    <font color=red>Only guy I know that can get out of line in a one car funeral
