Installing fuel pump on 350
Discussion in 'The Garage' started by wazzabie, Sep 14, 2005.
  1. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,721
    11
    Washington State
    Looking for tips/ instructions on how to install the fuel pump for a 350.
  2. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Take the old one off. If the pushrod falls down just stick your finger in there and push it up. If it falls down again take a bolt and stick it in one of the bolt holes in the front of the block (I forgot wich one). That will hold the rod. Then stcik the new one in and bolt it up. Then take the bolt out of the front of the block.
    Adam
  3. Big Truck
    Big Truck 1/2 ton status
    Feb 19, 2005
    129
    hermiston, OR
    Also try coating the rod with grease so it will stay up in there easier and turn the engine by the crank and see if the rod will go up in there more.
  4. wazzabie
    Apr 17, 2001
    1,721
    11
    Washington State
    by crank you mean by hand?
