Installing gears in a 14FF
Discussion in 'The Garage' started by MudFrog, Jul 15, 2004.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Ok, it's time to go to 5.13's, I need to know if installing the ring and pinion will be much harder then installing a detroit?
    About 2-3 months ago I installed a detroit and it was a piece of cake. Only took around an hour or so. How much harder is installing gears on the same axle? Any special tools required? I can get it done locally for $125 an axle but I would like to at least attempt the 14 bolt to save some $$$ if I think I can do it.
  2. monsterjim
    monsterjim 1/2 ton status
    Feb 5, 2004
    151
    north Texas
    if you've never put gears in I would suggest watching and helping someone who has before attempting it for the first time. You need a dial indicator for sure. Installing the locker is different cause your shims are all still in place and your depth and backlash is allready set, you didn't need to mess with any of that when you put the locker in. When you install new gears you are starting from scratch, Need to get your pinion depth correct with that damn crush sleeve, and get your ring gear shimmed on either side, its a tedious process but worth learning to do. Like I said, if it is the first time, get somebody to help that has done it before and you shouldn't have a problem.
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Installing gears in a 14FF is way, way more involved than just installing a Detroit.
  4. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Thats what I needed to know /forums/images/graemlins/thumb.gif
  5. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    something like gears is best left to people who know what they are doing....I'd rather pay somebody to do it right, then to have to do it twice /forums/images/graemlins/ignore.gif
  6. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Well I did mine with no experience, and it wasn't "hard" just time consuming. The crush sleve was the hardest part, but after that it's just trial and error till ya get it right /forums/images/graemlins/whistling.gif You will need a press, and a bearing puller, a dial indicator with magnetic base, and a lot of patience. I thought it was a cool learning experience, but I wasn't using new parts either so if I messed up it wasn't a huge deal. With new 5.13's and $125 an axle I'd have it done /forums/images/graemlins/waytogo.gif
  7. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    if you enjoy working on your truck, do it yourself. Its not hard. I did it and it was fine. Spend the money on new tools that will stay in your garage instead of throwong $125 bucks(i'm sure it will be more, just got that feeling).
    As post above said, dial indicator, press and inch torque wrench. /forums/images/graemlins/waytogo.gif
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I do it every day, VERY easy!!! You need a press for the crush sleeve, dial indicator, maybe an assortment of shims, makes it easier with the adjuster tool!
